A
AC Question
I have had my Droid Turbo 2 since November 2015, the original charger became loose and I had to wiggle it and position it just right to get it to charge, then it just stopped, I can plug it into something else into it and it works fine. So I went to Verizon and bought a new charger, worked great for about a month, then did the same thing as the original charging cable, so I brought it back to Verizon, they just swapped one cable for the same exact same one, well that one started doing the same as the other 2. No matter what usb cable I plug into it, I have to wiggle it and position it just right to get it to work, then it can not be touched or it will stop charging. I think its the phone port, not the cable. Has anyone else had this problem?
