Credit for this goes to trailblazer101 over at XDA developers Forum
So recently i decided to test some Odin packages i was experimenting with and as with any hack or modification there is a chance that something can go horribly wrong and it just so happened that it did. I somehow lost all signal to my phone and when i checked my baseband under settings>about phone it said UNKNOWN. I thought i was out of luck since no modem images are available for the Continuum as of now. Fortunatley there are people out there who are willing to think out of the box. trailblazer101 decided to flash the DL09 radio for the fascinate, AND IT WORKED!!!
Then i decided if that worked there was no reason EB01 modem wouldnt work, so i tried it and sure enough , IT WORKED!!! So now im back up and running.
So for whatever reason you lose your radio/modem on your phone download and use one of the following till an official one is released
Modems
Download DL09 from HERE
or
Download EB01 from HERE
Flash either one of those using Odin if you need directions they can be found here: http://forum.androidcentral.com/599598-post4.html
Thank you trailblazer101 for being exactly that a trailblazer
Modems
or
