if anyone knows how to and where to get new framework please let me know
just flash the rom again it will fix the framework, then pull it in adb or use root explorer to copy it and put it on your sdcard
Full battery pop up option works as advertised. No more bright screens in the middle of the night, thanks
Where might I go about finding this "option" in the phone so I can turn it off?
Hey!
Thanks for developing this ROM. It looks very smooth.
... However before I take this step, where is this stock ED1 ROM? I want to know in case I don't like the phone and want to return it for another one. (Though the screen is brilliant and I like how I can customize it already without root or a ROM)
Your looking to enable hidden menus and then follow the steps to disable the battery full pop up. Follow the steps in message #171. Works like a champ and verified on Altered Beast A3 and Stock.
is this rfs or ext4
getting in to adb or sdk or odin my knowledge is extremely limited, i want to learn, want to be able to operate in all those envirements. this is my only hobby could you please describe maybe where to get a book or a website or anything that may be able to to build some know how
DroidXCon donate link not working could you post alternative
Depends, as long as you leave voodoo lagfix enabled you are using ext4 but if you disable lagfix in some manner then your using rfs.
where do we go to check if voodoo lagfix is enabled or not? also is there a option to overclock the cpu?
Thanks
Just bought my DC today....will try it stock for a few days (yuck I know....)
Do we have a process to return to 100% stock ROM without VZ knowledge for return of phone?
