[Odin][Rom][6/20/11]AC's Altered Beast **Alpha 5** EE4 based
so if I do this... this just gives it "root" right????
if so... (and on ED2), can I put any ROM on it for the Charge after?
if you look at the original post it does alot more then just give you proof ....this is the only rom available for the charge at the moment
i am trying it now... what happens if i plug the phone in... with odin open and nothing pops in the box in the left?
Thanks for all of your help so far :). Vif this works (knock on wood). What do I need to do after to get the better batt life??? Sorry for the stupid questions. First time rooting a phone.
Nothing until there is undervolted kernels.....this isnt rooting this is flashing custom firmware , just happens to be rooted
Thanks for the guide DroidXcon. Gonna give this a try in the morning. Hopefully (fingers crossed) I won't run into any issues.
I did.... I can get the yellow triangle to come up on phone. But nothing happens in Odin
turn on the phone, put it in debugging mode plug it in and let it set up for a couple mins,
then disconnect remove the battery and tray again
good luck carla let me know how it goes
Reactions: carladarla
I'll try that.... Stay awake with me!! Hahaha.
Retrying...... Crossing my fingers.... If this doesn't work I'm a frigggin tard
Is the stock clock/weather widget going to be making a comeback in later versions by any chance? I had grown quite fond of it. If not would anyone happen to know where I might be able to find it? Thanks! :)
webdesigner
