[Odin][Rom][6/20/11]AC's Altered Beast **Alpha 5** EE4 based
Is the stock clock/weather widget going to be making a comeback in later versions by any chance? I had grown quite fond of it. If not would anyone happen to know where I might be able to find it? Thanks! :)
they work in this version
Oh that's awesome! Looking through the widget list, however, I don't see it. Is it listed anywhere else?
So..... I'd like to extend a hugeeeeeeeeeee thanks to droidXcon.... He spent well over an hour with me fixing a technical issue!!!!! Thank you again sir!!!!!
No worries, thank you very much. :)
Edit: Donation sent, wish I could afford to send more considering all the work you put in for us. Thanks for everything!
Reactions: DroidXcon
DroidXcon,
I am assuming a battery wipe may be in order since it is generally recomended when you switch Kernels like what we are doing vodoo right. Thoughts?
Good to see the 1st ROM for the Charge came from our lovely state and shows we can produce great things instead of just those Bennys on Jersey Shore. I may have to hire you to come down to Monmouth County and work on a contract we may get for custom Android development,,,heh.
-MV
The custom ROM is wonderful but I have decided to return my Charge. How do I remove the custom ROM?
Use Odin and flash the Rooted ED1 Stock ROM and then let the OTA upgrade hit the phone and you will be ED2 no root, stock.
I LOVE this so far DroidXcon.... Thank you so much!!!!!!! Looking forward to future updates :)
My friend has a Tbolt with a ROM on it that when ever he turns the screen off, it like fades to a white line. (kind of like an old school TV, when it shuts off). Thatd be AWESOME :)
working, love the signal. will metamorph icon themes work?
it should i dont see why not, gunnermike is working on themeing it with me i have shut down animation working with the help of jaekar, but go for it let me know how it works out
Absolutely nothing works with metamorph, following the usual route. If I could change this battery to the same one in blue it would be awesome. Any who this is totally great, great work
jacketempire
