Hi
Best way to find said tower? I downloaded some of the apps you suggested, not really sure how to use them.
Accused Samsung and Verizon fanboy from my Verizon Galaxy S5
There are websites that list towers but they are hard to use. I would suggest start by finding somewhere where you have 5 bars of service or at least 4 bars. Use open signal maps to see which direction the tower is in and head in that direction. Keep in mind that I say tower, but it could be attached to a building or whatever. Also, standing right under the tower won't get good signal. The way signal propagates, you need to be hitting the tower at a certain angle. After that, use the advanced signal status to watch the rsrp dbm, it should be decreasing as you get better signal. I find about 1000 feet from the tower gets optimal signal. But keep in mind that tower height makes a difference. There are also widgets that you can use to see signal strength. .
dpham00, Android Central Moderator
Sent from my Verizon Samsung Galaxy Note 3
