How do i transfer apk data from one phone to another
DaAweZomeDude
10
As the title says, I have a few apks that may or may not be modded, now I want to move them to another phone but I dont see where the apk data is stored. (Is this even the right place to ask about this? lol)
An apk file is just an installer file -- everything for the app installation should be included in the apk file. Are you talking about app data after you installed the apk and started running the app?
Yes, the app data
Which apps are these APK files ? If from another source then play store and native to system app most likely won't be able to save it's data but if we talking moded APK for premium service of a app it won't be allowed to be discussed here.
TonyN
