Manage Contacts/Labels
carrotmuseum
19
I run two Android 10 phones. One is my main personal mobile which uses all the contacts from my Google account - those with and without phone numbers, and email addresses.
My second phone is to be used as my home phone. I have created a Label in the Google app Contacts, named "Home Phone" and tagged all those contacts (with phone nos) who i would wish to ring from this phone. At the moment, on the home phone, when I select the phone icon - contacts - it shows ALL the people in the global list as in my personal phone.
All I wish to see is those who are tagged with label "Home Phone".
How can I achieve that?
This may vary some depending on the phone brand you're using, but should follow a very similar method regardless. On your Contacts app there should be a Menu button. There you can select if you want to see a specific account or All of your contacts. There you can create a 'custom' list where you can select which groups to show from a specific account, and hide other groups.
hanspl
