Transfer contacts from iPhone to the S4 without iTunes?
sirsimon40
Hello! I've bought the S4 and I'm switching from iPhone! But I found a problem that I don't have any solutions for. How do you transfer contacts from the iPhone to the S4 without using iTunes? I've tried Microsoft exchange as well but it doesn't work. Any suggestions?
Best regards // New android user
MikeA86
8
Export your contacts from iCloud as a .vcf file (make sure you select all). Then in Gmail import those contacts from the .vcf file you just made. It's a little work but it did fine for me. Just keep track of where that vcf goes.
Sent from my SAMSUNG-SGH-I337 using Android Central Forums
Non
