My XOLO Q700 doesn't connect to PC by USB Cable
ashishpsharma
5
My XOLO Q700 Android Jelly Bean doesn't connect to PC by USB Cable.
Even i had enabled USB DEBUGGING in developers option.
I had tried using another usb cable, to another pc too.
Even my friends Xolo q700 also doesn't connect.
Sent from my Q700 using AC Forums mobile app
ashishpsharma
5
Thanks a lot. It works.
But facing some different problem.
After connecting the USB Cable to PC, its get disconnect after a while and reconnect automatically and the processes repeats again and again.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,606
4,755
113
Glad you got the connection working, but not sure I can help you about the intermittent disconnects. You could try using a different USB cable to see if that's the problem. The phone's USB port could also be faulty, but it's harder to test that.
