I have a samsung captivate, i rooted my phone worked fine, then i tried to use root explorer to change the value of my install non market apps from a 0 to a 1 in order to remove it, then i rebooted my phone and it wont make it past the galaxy s screen it just goes black with no response, what can i do? the phone was rooted perfectly, not a problem, i will show you everything i did, i followed these videos, YouTube - How to install 3rd party applications on the Samsung Captivate Galaxy S device (AT&T 2.1 Eclair) that was for the 3rd party app reset, AT&T Samsung Captivate / Galaxy S root tutorial mounted it with these instructions, please help me, ive only had my phone for 2 months i need to get it fixed
