How do I transfer phone data. to a sd card on a LG?
A
AC Question
My phone is showing me my full phone data and empty sd data but i dont see where i transfer the data
icu
555
21
Re: how do i transfer phone data. to a sd card on a lg
Hello - so I'm assuming you want to move off some files from your phone storage over to your SD Card?
If so, the way I would do it is:
- I'd first determine where the most/biggest files were located using something like DiskUsage - https://forums.androidcentral.com/e...google.android.diskusage&hl=en&token=vC2Hw3sq
- I'm assuming it's photos and videos, but maybe some games/apps are taking up a lot of space. It's good to see it visualized like this.
- I'd then get a file manager such as ES File Explorer - https://forums.androidcentral.com/e...com.estrongs.android.pop&hl=en&token=CJy1zEaC
- Fine the files and/or folders you want to move - select them in the file explorer and choose "Move to" and select a folder on your SD card
tress
