How to disable LED notifications on my HTC?
KaiKuzuri12
My HTC Velocity/Vivid/Raider 4G LED light won't turn off at the top left corner of the phone :(:(
It is not blinking but a steady green light with a mixture of a little red. It is eating up my battery.
I have tried all possible solutions Rebooting/ Settings >disabled notification light / ROOT / installed a custom ROM / Battery pull / apps that manage LED notification lights like Lightflow, Flash notification. / turned off notifications for gmail( I don't even have any unread mails) / Factory Reset.
That light is still consistently on after all those things that I did :mad::'(
If anyone had a similar problem with this phone or any other brands. Can you please tell me how you solved it? Thanks :)
tress
