Why is my phone not charging?
A
AC Question
why is my phone not charging
I have tried 3 different chargers, and my phone will not charge. this is the second phone that has done this,
lsmachado
548
Re: why is my phone not charging
You didn't specify which device you have or it's age, but it could be a defective or failing battery, or the charging port could be bad.
If you have a device with a removable battery, make sure to take it out and place it on a flat surface. If it can spin around easily on either side, the battery is bulging and needs to be replaced.
Did you use a different charging brick with the different cables, or did you use the same brick? If you used the same one, the brick could be bad.
Also, did you try plugging in to different outlets?
Posted via the Android Central App on my Note 4
