A
AC Question
text problem
when I tap on contacts and then I select a contact there is a phone and message symbol. I can tap call and it works, but if I select message nothing happens. I can't find the answer. I can text from the text screen but this a lot more moves .
Thanks Senecaw
Thanks Senecaw
