How can I stop my Huawei from spamming?
A
AC Question
My huawei keeps on spamming.
My huawei ascend y330 keeps telling me
Unfortunately, the process com.android.phone has stopped.
then you'll see okay and when i click it, about five quick seconds later, it says that same thing again and i don't know what to do.
AlphaTango414
3,939
95
Re: My huawei keeps on spamming.
Wipe system cache via recovery mode.
Did you happen to disable anything right before this started happening? If system cache wipe doesn't work, you may be stuck with doing a factory data reset.
Non
