Screen is froze with the message firmware update do not unplug from USB connection, what can I do to fix it?
A
AC Question
screen is froze with the message firmware update do not unplug from USB connection
it is froze with that message on it .and will not power down or do anything at all
it has only been used 2 or 3 hours total
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,391
255
83
Re: screen is froze with the message firmware update do not unplug from USB connection
Contact the manufacturer's customer support for advice on how to proceed.
RandyRoyalty
