V vmbe New member Aug 29, 2016 2 0 0 Visit site Aug 29, 2016 #1 My Xperia using Android 4.2.2 shows no signal strength icon, even though there undoubtedly is a signal, because other members of my family standing next to me can send texts with their iPhones. Can any kind person help ?
D dexterouz Active member Oct 5, 2015 25 0 0 Visit site Aug 29, 2016 #2 From Settings > you can try to search manual network. Sometimes it works that way. If its causing you issue, try apps like Network Signal info and check the network stats. https://play.google.com/store/apps/details?id=de.android.telnet&hl=en Or if the issue is repeateing then you have to either re flash the firmware or take it to the service center.
V vmbe New member Aug 29, 2016 2 0 0 Visit site Aug 29, 2016 #3 Thank you, and I shall try that, though I must admit that I have got no idea what "reflash the firmware" means !
