When I plug the SD card into a reader and then into laptop, how can I see what's in the Android secure files? It says they are "ini." Files? It won't open.
If the files are secured by encryption, then the only way to see the contents of the files is to view them from your phone, as that is the only device with the decryption key.
Okay, thank you so much. Does it matter which phone? I have several sd cards and not sure which came out of which phone. Also, can it be viewed from a tablet? Thank you
