FIX****************************Hey guys I just wanted to post this fix. I may not be the correct spot to do so. Maybe the moderators will move it if need be. So the fix for this if you get this message when booting up is to download an app or apk file called SD Maid. It has nothing to do with an SD card. It is an app that will comb through all your files and app files and clean up your phone for you. Easy. When you delete an app sometimes it leaves behind useless files that can get in the way. This app will find those files and delete them among other useless files that are causing this error in boot up. Here is a link to a photo of what error looks like.
Redirect Notice
Redirect Notice
