Has anyone noticed their Android Messages app using more battery lately? If so, did it only start after activating Messages for Web? On my Pixel 2 XL running 8.1, I've noticed recently that Android Messages has frequently been the top battery consumer. Right now, my battery is at 54% after about 14.5 hours, and Android Messages is at the top of the battery list at 10%. It says it's been in active use for 1 hr 13 min (but I don't text that much -- the most I may have directly used the app is probably 10 minutes or so). It's been responsible for 260 mAh of battery use.
I'm going to see what happens if I deactivate Messages for Web. Not sure if this is the right way to do it, but I went to Settings>Apps, selected Android Messages, then App Notifications, then turned off the toggle for "Connected to Messages for web." Will update in a few days.
