Perkology
I'm experiencing the random shutdown as well. The frequency is not that high; I've had it for just over a week and it's happened three times, and then only when unplugging the charger never when plugging it in.
Contacted google support, got the standard, reset to factory defaults (i'm skeptical it will make any difference). If it doesn't work they'll generate an RMA. If they RMA every tablet that does this they must be going through tons of hardware.
You bought a used Nexus? I would be concerned buying any used device that hasn't yet passed the 1 year warenty mark.
not if the warenty is non-transferable. I was under the impression this is the case with the Nexus 10 Warenty
I installed v4.2.2 tonight and I have reason to be hopeful. I plugged and unplugged the charger a number of times (with the battery as low as 65%) without a shutdown. That never happened before with v4.2.1.
So far, I'm delighted -- but it's only been a few hours so the jury is still out.
