I am able to connect to my WiFi but after I download apps from either the Market or the Amazon app store I experience connectivity issues to any learned networks ONCE I reboot the tablet. it's as if during the download and/or install process of new apps corrupts the network PSK stuff. Weird this is...I don't experience any issues until I reboot (or turn off/on WiFi).
I can easily reproduce this and what I am doing for a workaround are the following steps:
1) install any new apps while using WiFi network no.1
2) go to wireless settings and forget WiFi network no.1
3) turn off wifi
4) turn back on WiFi
5) join WiFi no.1 and re-enter creds
Now i can reboot, turn off/on WiFi and connect back to WiFi network no.1 as often as I wish with no connectivity issues until I install new apps.
So I even reset things back to factory settings and can easily reproduce this. I even have this issue when I am using the wireless network at work so i don't think it is something to do with my access point specifically but I find this odd that not everyone is experiencing the same exact issue.
Any ideas?
3) turn off wifi
Any ideas?
