I have the new Mate 20 Pro and the do not disturb feature doesn’t work. I have turned it on and I still have calls coming through. How can I fix this issue?
Ok, its in "Define priority interruptions" in the "Do not disturb" menu, assuming that's the mode you have selected. In there you can say whether you want calls from all contacts, or favourites for example.
