I was just hoping someone could tell me whether there's a way to fix these annoying things on my new phone as I never had the issue before. First, every time I use certain apps, I get a notification to warn me that the app is displaying over other apps and I can select the notification to disable it. Can I disable this warning appearing as I'm already aware of what it's telling me and don't need to be notified constantly.
Also, even with the sound turned off, sometimes I get a message pop up to tell me that an app changed sound to vibration, yet it still makes a sound, and it tells me I can manually adjust the volume to recover sound. Again, I don't want to be told about this every time and annoying, it still makes a sound even though my sound is turned off and it's telling me the sound was changed to a vibration.
Finally, the notch settings are annoying. With the notch turned on, it obviously cuts a notch out of whatever is displayed. I would have thought that turning the notch off would cause full screen apps to begin below where the notch ends, but no. It just cuts a portion of the display off instead. So with Instagram stories for example, it cuts off the timer bars completely.
Is there any way to change these things? Any advice would be appreciated.
