Searched several forums this weekend for solution to disable annoying "battery fully charged notification". Other than "root" found
nothing. This works. Hold down the notification instead of clearing it. It takes you to system app, System IU (You can also get there under Settings>Notifications>Advanced>Show system apps>System IU also). Then Battery full>Importance>Select Low, "no sound or visual interruption". Recharged battery several times, never returned. Hopefully people can sleep at night now.
