You keep on saying good, define a good battery for your own use, cause my full day of usage for me is good. I told you what my brightness settings are on my previous post.
How much of screen on time do you get? I'm think that 4-6 hours is good.
What kind and where did you get if from? ThanksI've just installed a larger 3900 mAh battery, allowing me not to need a different rear cover and loving it.
I had switched to ART and wasn't happy with battery life and have tried back on dalvik and battery seems better. It's a wee bit laggy but not outrageous.
I'm no expert (read loads of reviews suggesting to switch to this to improve lagginess) ibut it's android run time. I believe lollipop uses this by default.Stupid question,but what is ART?
My G3 is getting amazing battery life. My phone comes off charge at 5:45am, and with medium-heavy usage throughout the day i am left with 40% when going to bed round about 10pm. Some days more, and some days less, all depending. However i am rooted and running greenify, Xposed framework with the amplify module (prob where im saving most of my battery). I have also set tasker to toggle my gps on and off with certain apps. Obviously not running ART as Xposed is not supported yet on ART. Also still running the stock launcher with zero lag.
I would double check that if i were you. I know if you try change to ART with exposed installed, it reverts back to Dalvik. sorry double postI also have the Amplify mod installed. Btw, I'm running Xposed on ART.
