DuncanFromLondon
That worked, Kris.
Well, not exactly as you said. It was pretty scary. The first time when I used reboot it didn't work. The second time I switched off instead of rebooting and it said something like 'reinstalling firmware don't unplug USB cable until done'. Of course the USB wasn't plugged in and the firmware install was at 0% so then I pulled out the battery. After which it started just fine, that horrible message popped up one more time ... and then stopped ... so far. I am scared to plug it back into the USB though.
Well it worked and I'd never have thought pulling out the tray so thank you, I am grateful you saved me a sleepless night and a call to LG.
