I have youtube red and use background play all the time at work to listen to old howard stern segments and other stuff. I load them to offline storage (SD card) and listen at work without using cellular data. It's worked great forever. Since this AT&T 7.0 upgrade, background play will not work - but only on offline videos. If I stream them from cellular they work fine. What's even stranger is offline background works fine if I use the google launcher. LG's launcher and Nova simply will not play youtube audio in the background if the screen is shut off and the file is stored offline. Playback just stops. I tried changing from SD to internal storage and it still doesn't work. Can anyone verify this behavior if they have youtube red? I tried a FDR and it doesn't help.
I do this to myself every time. I have a perfectly functioning device and KNOW I should wait for the early adopters of the updates to hash out the bugs but I just can't help myself.
