Hate to say it, but that version is no longer supported. Thekravens cm7 is the newest iteration out there. I would try that and see if that fixes you problem.
On thekravens cm7 in the first post toward the bottom, there is a section called hotfixes. #7 is the sprint vvm fix, that removes the 9017 text notification about voicemails.
