OK, well # means root, and you need root, and adb can flash a new recovery from inside of recovery. First things first, find and download a copy of xionia_cwma_12518.6.img or CWMTRecovery_5.0.2.7-th6_thunderc.img onto the root of your sd-card. You can either push the file via adb:
Code:
adb push <local file> /sdcard
don't type in the < >, and you'll find it much easier if you rename the recovery to recovery.img and move it onto the root of your c drive. Then <local file> would just be c:\recovery.img
or, if available, mount via USB storage from your recovery.
Once you have the recovery.img copied over:
Then you need to flash the recovery
Code:
adb shell
# flash_image recovery /sdcard/recovery.img
If that finishes without errors, you'll now be ready to flash the zvd update.zip
