A
Android Central Question
Bluetooth on T-Mobile keeps disconnecting multiple times during a call... Never happened with Verizon Galaxy phone. I don't know if it's the phone or carrier?
"During a call" would have nothing to do with Bluetooth, since calls don't go via Bluetooth, so it would have nothing to do with the carrier.
But Bluetooth and wifi do interfere with each other in some situations (like which channel the wifi is on). So it could be that (especially if you're using wifi calling, which Verizon doesn't have.)
Or you could be putting too much between the phone and the device it's dropping the connection with. An earphone, for example, is a Type 3 device, with a range of less than 10 meters in clear line of sight. If the phone is on one side of your body and the earphone is on the other side (especially if the phone is low down, like i n a pants pocket), that's going through about 2 feet of human, which is more than most class 3 Bluetooth devices can handle. (I used to get about 30 feet from a phone on my deck to my mailbox, but it wouldn't work from my left ear to my right front pants pocket.)
So check what's happening and what you're doing, and you'll probably find the reason.
