Was rebooting my wife's Pro last night and it died on me. Wouldn't reboot. The screen just had the white Motorola symbol and stayed like that for a minute or so. I tried pulling the battery then rebooting with the same result. Called Verizon CS and they walked me through a full master reset with the same results. If I try and reboot it and let it go for a couple of minutes I get like a DOS screen that says Bootloader and then some error numbers underneath. Further down that screen it says the battery is ok and to connect the USB cable.
Anyone have this happen to you? Going to run to the Verizon store after work if I can't figure it out.
