Now with a Turbo charge. An hour less screen time, but similar app usage, some BT streaming, and 10+ hours off WiFi. Something is up...
View attachment 158648View attachment 158649
This is not anything to complain about. Great battery.
I don't understand how that is "suboptimal". Only a handful of people that have posted here can regularly get more that what you're posting. Your numbers are on par with what many here get.Another regular charge, another suboptimal battery life. Next will be another Turbo Charge.
View attachment 159051View attachment 159052
Before you factory reset I suggest clearing the cache. Battery life doubled for me. If I hadn't been in the mountains and other areas without service I could have been looking at 60 hrs of light usage.I don't understand how that is "suboptimal". Only a handful of people that have posted here can regularly get more that what you're posting. Your numbers are on par with what many here get.
Before you return the phone, may I make a suggestion? Try a factory reset. Just for giggles. I'm thinking of doing it here too, just to see. If you're going to return it anyway, maybe that might be worth a try?
Sent from my Droid Turbo using Tapatalk
I've done the cache clear many times. Quickens the phone a little, but does nothing for battery life for me.Before you factory reset I suggest clearing the cache. Battery life doubled for me. If I hadn't been in the mountains and other areas without service I could have been looking at 60 hrs of light usage.
Clarity would have helped.You all are obviously not following my stream of posts. I am completely happy with the phone and battery life. My last post and the few before it are comparing Turbo charging with regular charging. Suboptimal simply means that I'm getting longer battery life with Turbo charging than regular charging.
Factory reset. Really?
If your returning the phone in the hopes that another phone will get this good of battery life, I wouldn't do it. I've seen people say their new G3 or S5 gets better battery life and I call bullsht. There is no way. Especially how the Turbo doesn't have all the bloatware skin crap the others have. Even with 1 d and 9 h of battery life why go through returning a great phone?
Based on suggestions here, I went and download/installed GSam to my Turbo. Anything special that I have to do to it in order to get it up and running? I basically just fired it up and that was it.
