Looking to read and send texts from my computer at work and have them sync to my phone...any suggestions?
Try sending a message when your phone has no cell signal. Moto connect needs you phone to have a cell signal where the messages+ app does not.
I don't think anyone said you have to be on the same network. Messages does sync everything to every device. Phone, tablet, computer etc.Motorola Connect doesn't need to be on the same network.
With Verizon's Messages+, I don't think sent messages sync back with the phone unless you use Messages+ instead of Motorola's SMS app.
Posted via Android Central App (Moto X)
If you are on the same WiFi network and use chrome browser, you can use moto connect which is already on the phone.
+1 for VZW Messages+. Advantage over Moto Connect is it will work on any wifi/Internet connection - it doesn't require your phone be connected to the wifi.
Good grief. Can't believe this is becoming a pissing contest. Let me sum it all up for you tdizzel. Moto connect needs a cell signal on your phone and messages+ does not. If you never lose cell coverage use whichever one floats your boat. If you do go outside of cell coverage it's something to keep I mind.Yeah, umm...ok
