Any word on if there will be functionality for data while on a call? I routinely check routes via GPS while on calls, and right now I can't. Is that included in the VoLTE update?
Also, after updating to Advanced Calling, you're supposed to wait 5 minutes, then restart (it will tell you this, mine did). When mine restarted, it took at least an additional 5 minutes before I had phone service. I was getting a bit worried, but eventually, all the pieces fell into place and the phone worked as it should.
I have a business account. I need to wait till Monday to activate it. I'll update when I can try it out.
You certainly may be right, because I didn't have that feature enabled before the update (I didn't see a reason to), so in my particular case, when I went into settings, Advanced Calling, I had to turn it "on" which then went through the process I mentioned earlier.Please let me know if true, but I read that this is the case if you've installed the update first, and then enabled the HD Voice on your account after that.
If you've done it the other way, having enabled HD Voice already and then updating, I believe that you're good right off the bat? The phone reboots as part of the update process, and after that I don't think I needed to wait for service. Also somehow I don't remember reading about the 5 minutes - BUT I could be way off because my memory (and attention span at times) stinks.
Maybe it's my 1:41 a.m. brain mush, and for that I humbly apologize, but an update was released or am I misreading? What version should I be on right now?
I can't confirm that 1st part, but I do know that update 21.44.8 started rolling out last Wed, 12/10, enabling VoLTE-associated capabilities and also including various other bug fixes and improvements. Here's the main info page about the update:
Advanced Calling 1.0 - Verizon Wireless - Verizon Wireless
If you haven't already updated, here's a Cliffs Notes version of the update procedure: Go to "System updates" in settings and download/install update, enable "HD Voice" feature on your line in your VZW account, wait a few minutes, reboot, then turn on "Advanced Calling" in settings.
There's no official list detailing all of the update's specifics, so a dedicated thread was started for listing features/improvements/fixes that were discovered. Apparently, that's been merged with another thread or two. The specific page in this now-megathread where that list started is post #287 here (though the whole thread is worth reading):
http://forums.androidcentral.com/mo...d-turbo-volte-simultaneous-voice-data-12.html
Let us know if you're still having reception issues after the update. Enjoy the new phone & updated features!
I got the phone in Tampa on Friday, but left for vacation for Central Ohio on Saturday, and every time I go on a call, my signal goes from 4GLTE to 1X. Not sure if it's towers or what, but I'm now keeping an eye on this thread as I do the initial "tweak the phone" process.
Moo Cow, you are doing something wrong when you leave Florida to go vacation in Central Ohio. Do they ski in Ohio? Something doesn't add up ...
I have the feature on my account and I've done several restarts. It still doesn't work on my Turbo.
If you've followed posts #2 & #10 above and simultaneous voice/data still isn't working, then I can think of trying the following - keep going in order if the previous one doesn't take care of it:
1. Clear your cache partition: Wipe Cache Partition DROID TURBO by Motorola | Verizon Wireless
2. See if it works in safe mode and then test individual apps for conflicts: Restart the Device in Safe Mode DROID TURBO by Motorola | Verizon Wireless
3. Call VZW tech support, then maybe Motorola tech support
4. Factory data reset
Note that #1 & #2 can also good for lagging/freezing (referring to your post in another thread). Anyway, others better than me I'm sure will have more suggestions before having to go nuclear with #4.
Did you get the OTA update yet?
Settings / about phone. What are the numbers at the start of "System version"? If it is not 21.44.8 (I think...), you need to get the software update for the phone. I think it should be available from Settings / System updates by now.
