Will 122° on a droid turbo damage the phone and if so how do you keep it from getting that hot while charging
Are you using the Turbo charger that came with the device? If so, then it's common for it to get a little warm (from what I've seen through online searches). I couldn't tell you what is safe and what isn't in terms of high temperatures. But if you are using the device while charging I would suggest discontinue doing that. At least, don't use any apps or services that cause the device to work harder than usual.Will 122° on a droid turbo damage the phone and if so how do you keep it from getting that hot while charging
Sorry off subject: Have you had an issues using your qi chargers with the turbo?I assume the safe temp range is in the Turbo literature somewhere, but I don't have time to check this morning. That's the definitive answer if present. For those suggesting that the Motorola Charger is the only safe solution, I respectfully disagree. As I understand it, the Turbo charge is not a Motorola technology, it's a Qualcomm technology specification. If that charging unit is certified as using Qualcomm Quick Charge™ 2.0 technology, (and itsn't defective), there's no practical reason to use it along with the Motorola that came along with your phone. I use the Moto charger at home, and a third party turbo charger at work, along with with two different brand of of Qi chargers (Nokia and TYLT). No overheating from any of them.
Not at all. I've been very happy with them, and I probably charge 90% of the time using QI.Sorry off subject: Have you had an issues using your qi chargers with the turbo?
Sent from my DROID Turbo64 via Tapatalk
