Anyone else have this issue with the Turbo? I've rebooted, even did a factory reset and still won't rotate..
How long did this issue take to resolve? My son had this happen to him last night. I rebooted but, no luck.I got stuck in landscape orientation in the YouTube app earlier, but it resolved itself. Maybe you have a faulty accelerometer? Try downloading some kind of car racing type app that uses your accelerometer to steer (Extreme Car Driving Simulator has it- https://play.google.com/store/apps/details?id=com.aim.racing&hl=en
Take your SIM out, reset the phone and set it up again with your account etc. Then insert the SIM again.How long did this issue take to resolve? My son had this happen to him last night. I rebooted but, no luck.
But, the phone doesn't have a Sim card.Take your SIM out, reset the phone and set it up again with your account etc. Then insert the SIM again.
You'll loose all your data when resetting though so only do this if all else fails.
Thank youYes actually it does, carefully remove the volume rocker by pulling it straight out, it lives under there. Consult the owners manual or if in doubt take it to a Verizon store.
