I primarily use the Google Camera on my Turbo but I have run into two issues that I'm concerned about. I'm wondering if others are experiencing these problems (a software bug?) or if the problems are unique to my phone (a hardware issue?)
Troubleshooting steps I have taken
Neither of those steps have helped.
- Lens Blur no longer works on the main camera. I can capture the image without issue, but when my phone tries to process it the end result is a normal photo that I cannot adjust the focus on - it does not have the little shutter icon below the photo. Oddly, Lens Blur works fine if I use the front facing camera.
- When I try to take a panorama the camera "drifts" on its own. I take the first shot and try to rotate the camera but the blue dot that I'm trying to land on drifts away from the white circle so that I cannot capture the second shot no matter how far I rotate the camera. If I use the motorola camera I can take panoramas without any problems.
- Cleared the cache on my phone
- Uninstalled Google Camera then reinstalled it
