EDIT: It has died. See below in the thread.
I have not downloaded anything in the last 24 hours that is new. If i updated anything it was existing apps that never had issues before.
My WiFi is turned off and won't turn on. I have a WiFi auto-on program for when i am, per cell phone towers, near a WiFi area I use. I've used it for multiple phones so that's not it.
I've powered down, powered into the menu and cleared the cache. The only thing I have not done is a full blown wipe and factory reset.
What would cause my WiFi to do this? Are there other issues I should examine before a full wipe from scratch?
Im on a limited data plan for cost reasons and I am near WiFi a lot so I figure why should i use data I don't have to?
It just did this in the past 24 hours and 3 apps updated. I can uninstall them but will that work?
I am at a loss here what to do. I do not want to do a full wipe but if I am forced to I suppose I will. But this is so odd it just magically quit working. Even going to settingd to turn it on fails. Bluetooth seems to be working. WiFi is a no-go.
Any advice?
I do see the Droid Maxx thread in here but that is a different phone so who is to say these are one and the same?
Any advice?
