is it possible to go straight from froyo to the gingerbread leak .595?
lions80
70
Hi, i just got my phone replaced because it would no longer charge the battery, and was looking to get the leaked gingerbread .595 update on the phone. Can i go straight to .595, or do i have to install all of the leaks prior to that in order and work my way up to .595?
Im guessing i can just go straight to .595 but dont want to mess anything up.
ndwatkins
144
11
You'll have to install the 3-part .588 update first, but after that you can go right to .595. If you try to go right to .595, you'll just bootloop a bunch, from what I understand. Hope this helps :)
wildman
2,158
230
Actually after .558 they have to go to .591 and then .595 for it to work correctly.
lions80
70
well, i went from .588 straight to .595. Everything worked out just fine. New phone is working properly. Thanks for the tips!
wildman
2,158
230
Thanks, I never tried to do this because p3droid instructions reported it wouldn't work, good thing to know now..
ndwatkins
144
11
Huh, I didn't know that :) I'd always just been doing it the Froyo-->.588-->.595 way with no probs. Well if it works it works I guess, I wonder if there was a reason for that from before when people were having issues with some of the leaks in the TBH app.
Either way glad everything worked out for you :)
danishpeer
