Hi,
I've searched the internet and can't find anybody with the same problem or a fix. My Nexus 6P will no longer auto connect to wifi. I go between home and office and the only way to make it work is to turn the phone off and back on, at which point it connects. If I look at the available wifi list, it says no networks are available. If I turn wifi off and on, nothing changes. I've checked the Advanced wifi settings and have 'Always' Keep wifi on during sleep. I've tried using the different frequency bands, I've even done a network settings reset in the 'backup and reset' section. So far nothing has fixed it and it's killing my mobile data allowence because I often don't remember to switch the phone off and back on every time I walk into my home/the office.
Any ideas?
Thanks, Chris
Any ideas?
Thanks, Chris
