I've noticed that for the past few days the battery has been draining faster than usual. I charge the phone to 100%. Then turn it on.
After roughly 3-4 hours, on standby, with no usage (after being charged), the battery has gone down to from 99-98% to 82-80%. The Adaptive Brightness is on, screen brightness is low, both Battery Optimization and the Adaptive Battery functions are enabled and working as needed. I checked the apps and cannot see any of them overusing the power...
Strange enough once I start using the phone then the battery seems to stabilize...
Also, even weirder, I have a mobile charger and if I top up the lost power and get the device back to 97-95%...then the power does not seem to drain at the same rate as before, but as it normally does.
Anybody experienced this? Could this be due to the current OS version, some core app or function draining the power?
My concern is that this is a new device. And the drainage occurs on standby. I charge the phone regularly. I don't over or under charge it... Moderate usage.
PS Would using and draining the battery to 0% and then charging the device help? Any other advice or info?
