[ROM][WIP-ALPHA7][CM10 PORT] Jelly for Optimus V
Status
Not open for further replies.
andrewnelson23
795
145
Re: [ROM][WIP][CM10 PORT] Jelly for Optimus V
Yes, the sd-ext scripts will fix the app disappearing problem. Make a working folder ;) haha I don't know. :p
nitestalkr
889
261
@Zackman, i noticed that the following isn't included in the update-script of the ROM, I'm not exactly sure if its needed or not, or what significance it serves, of if it's even needed at all.
Code:
assert(getprop("ro.product.device") == "thunderc" || getprop("ro.build.product") == "thunderc" ||
       getprop("ro.product.device") == "VM670" || getprop("ro.build.product") == "VM670" ||
       getprop("ro.product.device") == "thunderc_VM670" || getprop("ro.build.product") == "thunderc_VM670");
EDIT:
Backing up my phone now, and going to try out the sd-ext scripts :D
EDIT:
Now testing if the sd-ext scripts worked, by installing as many random apps from the market as i possibly can :p
EDIT:
Well, I'd say after installing 153 random apps, it's safe to assume the scripts work xD
andrewnelson23
795
145
NOVA. Allows the resizing of widgets :D
(and lots of customization)
Edit: idk if apex does. never used it.
nitestalkr
889
261
Which launcher? Apex or nova to be implemented into alpha 4
I say NOVA, its what I always install afterwards :p
And, I'll upload the sd-ext fixes for you to use in alpha 4.
I'm not sure if the scripts caused it, or if it was in alpha3, but when i access storage from settings, it force closes..
but at least the scripts work :D
sent from my un-dead sammich.
nitestalkr
889
261
@Zackman, instructions are included in the zip, this is NOT flashable(however, I will include this in all of my patches I made, by Saturday.), and this is to be implemented into the ROM.
andrewnelson23
795
145
how is it different than your super fix that included the sd ext scripts in it??
nitestalkr
889
261
These ones do not require the ROM to be booted first, and they are init.d scripts, so they work upon install of the ROM.
I manually pushed these scripts into Alpha3 to see if it works upon install of the ROM, and it does. So, I'm going to put these into my super fix as well, 'cause these are easier to install than the ones i already have.
These also produce absolutely 0 install errors, where as the ones in the Super fix will produce an error due to them needing to be booted before installation.
These are just overall better than the ones I used originally. :p
andrewnelson23
795
145
I'm at a loss for mms, guys.
LASDFKJ A;LSDFKJ;ALSDK FJ;LASKDFJ;LASKDFJ;ALSDKJF ;IDUF OEWIL ,.CXKJVH;LSF!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! .
I was SO close! stupid sending sms. ugh. I'm just still too much of a noob for this. -_- :mad:
cole2kb
Retired Moderator
Apr 7, 2011
2,503
547
Make sure you have permission to include Nova or Apex. Although, I'd prefer you include the default CM9 launcher and let us install our launcher of choice, because updates to /system apps from the market cause major headaches.
Reactions: sellers86
nitestalkr
889
261
Well also, the market will not automatically update user apps located in /system/app by default.
And launchers don't need to be constantly updated(unless its a fairly new release of such), so that minimizes the update headache.
Nova seems to have fewer updates as well, which also gives it a plus.
After all, AOKP often uses Nova as the default launcher in most AOKP builds.(although this is cm10, and not AOKP, just making a reference to how Nova would be a better choice IMHO)
sent from my Zom-"Bean'(CM10 JellyBean).
cole2kb
Retired Moderator
Apr 7, 2011
2,503
547
I tend to see updates twice a month or so from Apex, and I'm a Pro user. I suppose I could just swap it out for Trubechet (sp?) myself in the ZIP and install Apex Pro from the market too, no big deal there.
sellers86
1,837
617
Code:
EDIT:
EDIT:
EDIT:
These are the asserts that causes problems with some recoveries. They aren't needed, and they cause problems. Congrats on the scripts!
Master Gowa
Active member
Jun 24, 2012
28
4
@nitestalkr: Can I just use ES File Explorer to put the app2ex files in the right place or is there more to it than merely having the files in place?
JadenBrown30
131
31
Just thought I'd mention this, but when I download my cover art using Cover Art Downloader it works until I reboot my phone, then all the album art disappears. Don't know if its a bug with the ROM or app but I thought I'd just throw that out there.
sellers86
1,837
617
If its a flash able zip flash it if not move them to the right place and set the correct permissions.
nitestalkr
889
261
You can try it, just set permissions to r/w in /system.
And then reboot, and report your findings.
Or, you can wait till I put it into my patches(will provide a separate flashable zip containing the scripts as well) sometime Friday or Saturday in my free time.
anthonycr
Themer. You've seen them
Jul 11, 2011
2,104
571
I'm pretty sure they should be r/w/x otherwise they won't execute.
Status
RandyRoyalty
