[ROM][WIP-ALPHA7][CM10 PORT] Jelly for Optimus V
Status
Not open for further replies.
Re: [ROM][WIP][CM10 PORT] Jelly for Optimus V
App to Sd is currently being worked on by me, I'm close. The storage is read in system/storage but apps wont move yet.
"I had the same problem on 2 different versions of CM on 2 separate phones. This fix worked both times. Use root explorer, and make sure it is set to R/W mode (read/write). Navigate to /data/data/com.android.providers.telephony/databases/telephony.db and delete that file, then restart your phone. After the restart, you should be able to send and receive MMS messages."
- Anyone try?
Nope, doesn't work :(
Anyone wanna help me put the CAI Test15 Kernel in the boot.img? I'm on windows and have no idea what im doing.
i would help but im trying to figure out how to unpack and repack boot.img's its hard and dsixda kitchen wont set up so im trying if i find anything i will letya know and if i learn i will gladly do it
Reactions: Zakman
Yeah, you have to decompile the boot.img using dsixda's kitchen. I've never done it, and I won't have time today, but that would be a fun project. :)
Reactions: jonny5449
Been playing with the alpha 3 for a few hours now, SLICK!!!:D
However it keeps rebooting automatically every so often, is there anything I can try to prevent this?
Thanks
Perhaps try overclocking. It has the kernel from quattrimus and oc ing seemed to solve reboots in quattrimus.. .
Reactions: adamhos
also, since jb is different then ics, i don't think we can use an ics kernel.
You can use a .35 kernel on ICS. .35 is gingerbread. Nook color is still using a froyo kernel on ICS. Kernel doesn't make as much of a difference as people think it does.
Not sure how your having trouble with dsixda, it was probably the easiest thing I've ever done. Make sure you have a working folder or you won't be able to recompile.
Status
aimalee
