[ROM][WIP-ALPHA7][CM10 PORT] Jelly for Optimus V
Status
Not open for further replies.
andrewnelson23
795
145
Re: [ROM][WIP-ALPHA5][CM10 PORT] Jelly for Optimus V
It could be your phone's processor problem. Or it could be the kernel. Try switching the kernel. If that doesn't work, it might not. It could be that this rom on your phone on this rom is just too unstable at the default oc settings, and you can't change the defaults unless you're booted...
Reactions: lattimorej1986
lattimorej1986
60
15
Ok. I do flash test kernel 15 after gapps, so will try without flashing kravens kernel. If that doesn't work, I can change the default clock speeds on my first boot (its the second boot that's giving me problems) , so we will see if either of those help. I will report back. Thanks guys, and please feel free to come forward with any other ideas as to what the problem could be.
It's just odd it boots the first time, but not the second. I've never encountered this problem.
K
kobequintana
If that doesn't work try downloading every thing again than flash
lattimorej1986
60
15
Tried all three of these, with no luck. Can still boot the first time, after installation, but a reboot after that just hangs at the boot animation. Any more suggestions guys? This is bizarre, and i would really like to figure it out. I will do some more Google'ing, but if you have any ideas, please share!
lattimorej1986
60
15
buy a new sdcard... or try reformatting the one you have... (copy sd to pc)(copy back after formatting)... ?
The sd card that I have is relatively new, a class 10 16 gig. But I will try to reformat once I get home (3 hrs) and post back with the results of that as well. Thanks for all the suggestions so far guys! Someone has to know what's going on here...
lattimorej1986
60
15
Ok guys, for some reason reformatting and repartioning my sd card allowed me to boot the second time. Can anyone shed any insight as to why this made a difference? After all, I replaced all the files back onto the sd card that were there before the format. This one has me scratching my head in confusion. At any rate, it worked, and thats all that really matters.
Thanks guys.
ShadowEO
337
96
Thanks guys.
Probably filesystem errors. You don't need to format. A simple chkdsk on the card would've sufficed.
Sent from my LG-LS670 using Android Central Forums
lattimorej1986
60
15
Thanks, I'll keep that in mind in case I (or someone else else) runs into that problem in the future.
Sent From My JeLLyBeaN'd / MiRaGe'D Optimus V
androidCHEECH
22
I'm bout to try this ive been using cm9 Bobz rom for a good month now waiting on a steady jelly bean from from what I'm seeing its steady enough for me , great job on the steady updates
kenharkey7
222
18
Great work with the rom so far. Everything I need is working, and haven't had any problems with this. Using the test kernel really helped a lot too. Can't wait to see how this one goes.
10069618
12
Everything runs very smoothly so far :)
The only problem I have is that when I dial a number there doesn't seem to be any dialing tone when it's connecting to a call. I know that it's connected since I dialed my house phone and it rang, but is there any option to turn the dialing tone back on?
Edit: Fixed it by flashing the kernel.
cole2kb
Retired Moderator
Apr 7, 2011
2,503
547
I saw a couple of posts about this, but no real resolution. You guys using the test kernel, do you have working Wi-Fi? I flashed it, and it borked Wi-Fi, so I wiped and re-flashed without it and it seems to be working just fine, but would like to use what's recommended.
Status
tress
