[ROM][WIP-ALPHA7][CM10 PORT] Jelly for Optimus V
Status
Not open for further replies.
Re: [ROM][WIP-ALPHA5][CM10 PORT] Jelly for Optimus V
I saw a couple of posts about this, but no real resolution. You guys using the test kernel, do you have working Wi-Fi? I flashed it, and it borked Wi-Fi, so I wiped and re-flashed without it and it seems to be working just fine, but would like to use what's recommended.
Im at the library right now, using alpha 5 with the test kernel and i've been on the wifi for the past 2 hours almost with zero issues.
Edit: I think I found the weather widget you guys wanted Weather Eye
Weird. I'll give it another shot then. Thanks.
It probably doesn't make a difference but i didn't flash the test kernel right away, i flashed the rom after a full wipe, booted into it then rebooted and flashed the test kernel
I believe the weather widget you are talking about is already part of the rom. Its a lockscreen widget.. Go to Settings-> Lock screen -> Weather then check the box next to Display weather. It uses Yahoo! Weather.
But they want the status bar weather
Weather Eye came up in a reverse image search, either way its a pretty cool little app
I'm gonna download, if it is it, I can't believe how stupid I am.
I used this app for thr month of July. :)
No go, and I believe it's not Status bar weather. Its behind it, a widget.
I tried to flash with the test kernal but it wouldn't boot, so I did another full wipe and flashed without the kernal and it worked just fine but when i was using wifi my data was constantly in use and when I got a call I tried to use my headphones but the phone didn't recognize them and the speaker didnt work and the sound was mad low I don't know if that's a known issue but as for those issues everything else seemed to be workin
Try to re-download every thing than re-flash
Xperia S slightly modded. No share button, faster paging, themes stick.
Weather in screenshots is a screenshot of the Lock screen. It's weather enabled in the lock screen.
Every time I reboot my phone it says optimizing X of X after the boot animation is that a bug or what
Status
Xpornefar
