lfaber2006@gmail.com
I'm not really sure to be honest. I've read somewhere that claims you need it turned on to tether the phones internal GPS to your computer.
When flashing anything I usually just wipe cache and dalvik ONLY if it's the same rom. Maybe also for something like Zefie's and aospCMod, as they are essentially the same thing. So I'd do it for themes as well.
i am missing the market and maps applications, where can i get these?
Just thought i'd let everybody know.. With Google Navigation, the "Voice search" function is gone completely. If you go into the voice settings in the phone itself, it also looks like a setting is missing. Wasn't there two choices?
I've been using this rom for a couple of days now with no major problems. That is until right now: the phone will boot to the CM7 loading screen and stay there. Any idea what is causing this?
I know everyone says its the hardware and not the ROM, but I have been running Zefies CM7 for 2 weeks stable at 806, but on AOSPs I can only get to 748. why?
No....I have given up and gone back to Zefies CM7 at least for now because after it rebooted the 5th time I had a damaged sd card that nothing fixed, so I pulled out my handy nandroid backup.Did you do a long benchmark?
So I was a Noob to the Optimus V as well as Android itself. But just in case someone was having problems gettn a str8 easy to follow run down on getting this going here you go...
1.ROOT OPTIMUS V
2.dOWNLOAD " *ROM TOOLS"
*IN ROM TOOLS FOLDED
*DELETE RECOVERY.IMG REPLACE WITH CLOCKWORK FILE
*RENAME CLOCKWORK FILE TO " VRECOVERY.IMG "
*RUN ROM TOOLS AND SELECT FLASH RECOVERY TO PHONE
*CHOOSE THE OPTION OBTAIN ROOT AND FLASH
3.PUT THE MOD ON YOUR SD CARD
*BOOT INTO RECOVERY
YOU NOW HAVE THE CLOCKWORK RECOVERY DELETE THE CAP AND DATA
4. FLASH ROM.ZIP TO PHONE
5. REBOOT AND WHALAH!
This Rom is awesome by the way! Big Ups to the Creator!!
How to flash the Clockwork Recovery Flash the ClockworkMod Recovery - ROMRepo
