w0rd#AC
What does white/grey 3G/wifi symbols mean? That the connection is initializing and not ready yet?
Yes, all you have to do if it happens is set your whole hand on top of the phone then pull it off. At least thats what I do and it makes it work.Anyone run into this?
When you make a call, and the proximity sensor shuts off the screen, after the call, the phone freezes with a blank screen
I'm having issues with the voice dial physical button, and the button on my headphones
I just went back to stock ROM. I couldn't put up with the assortment of problems, eventhough I did dig the enhancements a lot. Stability and functionality wins this round.
Can we get a list of things that don't work on this ROM?
I thought this was nightly updated for bug fixes? or is that just the Optimus is version?
see aboveHere is Zefie's CM7 with tweaks for the Optimus V. I will try to build whenever he has new changes or there are significant fixes in the CM7 source.
