But can you use that fix nd duz that fix fix mms?
1) Don't start a sentence with "but"
2) "duz" isn't a word
3) You repeated "fix"
4) You misspelled "and."
To confirm what works here from the files/links in the Cold as Ice Thread's 1st and 2nd posts:
The actual rom itself, 10G, the current latest (11a is starting to be tested)
The framework file listed in the 2nd post that is for VM (this changes anything that says Sprint to VM
The a10 keyswap
Themes
So far, the stuff that works for 10F seems to work for 10G. Anything not mentioned (the audio fixes, etc) I have not tried. The next thing I want to do is implement the build.prop tweaks but I don't have time for that at the moment.
For MMS: Just use GoSMS. It's the easiest way to do it and it works across every single ROM.
